Normal Topic Z-Index in Contrainer (Read 3911 times)
mazelin
Jun 16th, 2009 at 9:47am
I add two Nodes to Contrainer, than I use Z-Index to control one looks above or below another. But I find the Z-Index will effect the Contrainer.
I need only the Nodes in Contrainer use  Z-Index.
How can I do it?
Re: Z-Index in Contrainer
Reply #1 - Jun 16th, 2009 at 11:31am
You might have set the child's ZIndex to be smaller than container's ZIndex. What happens if you set container.ZIndex = 0 in the end?
mazelin
Reply #2 - Jun 17th, 2009 at 4:18am
It's can not work.
mazelin
Reply #3 - Jun 17th, 2009 at 4:23am
I mean the two child nodes need use Z-Index, container is ok.
Reply #4 - Jun 17th, 2009 at 5:42am
Have you added the child nodes to the diagram before setting ZIndex? This won't work, unless you move the ZIndex assignment after the Nodes.Add call:
ShapeNode node = new ShapeNode(d);
node.ZIndex = 1;
d.Nodes.Add(node);
mazelin
Reply #5 - Jun 17th, 2009 at 1:01pm
I add two children nodes, like this:
shapeNode.ZIndex = 1;
contrainer.Children.Add(shapeNode);
One of two is larger.
Than, the smaller move to the larger one.
If i do not set ZIndex, the first add node will below second.
If i set ZIndex, it can not work.
I need the smaller is up to the larger one forever.
How?
Thanks!
Reply #6 - Jun 17th, 2009 at 1:19pm
Are you setting ZIndex of both child nodes to the same value? This is now allowed, and the second ZIndex assignment will shift the other items up in the Z order list.
