Normal Topic Resizing/Modifying breaks connectivity links (Read 3243 times)
kaykay15
Apr 26th, 2010 at 11:12am
Hello Team,
When we resize/modify a node or change orientation of the diagram, some of the connector links break as shown in the link provided below
http://docs.google.com/leaf?id=0B4xAPIW5oeouOGUxY2YzYjEtMGYzMC00ODRlLTg5NTgtNjgw...
What could be the possible reason for this behaviour and how do i overcome this issue?
Thanks,&&-KayKay
Chandermani
Re: Resizing/Modifying breaks connectivity links
Reply #1 - Apr 26th, 2010 at 11:25am
Adding to the facts. We started facing this issue once we set Diagram LinkCrossings property to "Cut"
It was earlier "Straight"
Chandermani
Reply #2 - Apr 26th, 2010 at 11:29am
I suppose that's the cut appearing there. Are there any invisible links in the diagram by chance?
kaykay15
Reply #3 - Apr 26th, 2010 at 11:58am
No there are no invisible links.
Thanks,&&-KayKay
Reply #4 - Apr 26th, 2010 at 12:27pm
What do you mean by 'change orientation of the diagram'?
kaykay15
Reply #5 - Apr 26th, 2010 at 12:35pm
Vertical/Horizontal orientation Diagram property.
Changing the orientation of the diagram from horizontal to vertical and vertical to horizontal results in the connection link breaking.
Or just resizing the node results in connection link breaking
Thanks,&&-KayKay
Reply #6 - Apr 26th, 2010 at 12:45pm
I don't know of such property in Diagram. What's it name exactly? I can't reproduce this by just resizing and moving nodes around, but it might depend on that property's value...
