Normal Topic Requires Edit Mode for diagram (Read 1278 times)
Bala
Jul 6th, 2009 at 1:37pm
Hi Stoyan,
I have some nodes and links in my diagram. I can do lots of operations on these items.
Now I want,
1). If I set a mode say Edit Mode than only user can do any modification over diagram(like add some nodes and link, delete some nodes and links, move object position etc.)
2). Else diagram should behave as ReadOnly and user should not be able to move/add/delete the diagram items, but user can click/rightclick/double click over any diagram item.
Does MindFusion supported this kind of ReadOnly behavior for diagram?
Many thanks in advance,
Bala
Re: Requires Edit Mode for diagram
Reply #1 - Jul 6th, 2009 at 2:04pm
Hi Bala,
You could set diagram.Behavior = DoNothing to implement read-only mode. This will prevent users from modifying the diagram, but the control will still raise click events.
