Normal Topic How to save and load my customer node from xml (Read 1365 times)
Fanli
Jun 6th, 2012 at 8:05am
Hi Stoyan,
I create my own node class by deriving from DiagramNode In my project and I know i will override the SaveToXml and LoadFromXml methods of the DiagramItem class. But It doesn't work. I hope you can give me some help or a demo about it?
Best Regards,
Ferry
Re: How to save and load my customer node from xml
Reply #1 - Jun 6th, 2012 at 8:21am
Hi Ferry,
Apart from overriding the Save / Load methods, you must also call the RegisterItemClass method. The code below is from Tutorial 4, which shows how to implement custom serialization and undo/redo.
// enable serialization of the custom class
Diagram.RegisterItemClass(typeof(OrgChartNode), "my:OrgChartNode", 1);
