Normal Topic Arrow origin change on table move (Read 3518 times)
Daniel
Jul 17th, 2009 at 9:31am
I got tables that look like the following:
The problem is, that when I move the table around, it looks like this afterwards:
The anchors just jump around. What could be the cause of this? I'm using Flowchat.NET 4.3.1 with .NET 2.0 and a custom behavior.
The second problem is that the tables to not allow self connections. How can I do this?
Greetings,
Daniel
Re: Arrow origin change on table move
Reply #1 - Jul 17th, 2009 at 12:56pm
That might happen if the links' Dynamic property is enabled. Set AllowReflexiveArrows = true to enable self-connections.
Daniel
Reply #2 - Jul 17th, 2009 at 2:03pm
thanks for your help. The arrows Dynamic property did the thing. I don't know, why I turned it on in the first place... Cheesy
The AllowRefLinks property also works, but not as expected. If I connect any of my n-outputs with any input I always get the same.
After that I can set the arrow to the in/ouput manually, but I will always end in a bezier curve instead of my nice cascading arrow.
This wont even change, if I set the arrows style to cascading inside the ArrowCreated event handler.
Daniel
Reply #3 - Jul 17th, 2009 at 2:41pm
In ArrowCreated first set SegmentCount to a value greater than one before changing the Style to Cascading. You might use the methods from this thread, though I don’t know how well they will work with the 4.3.1 API:
http://mindfusion.eu/Forum/YaBB.pl?board=wpfdg_disc;action=display;num=123843592...
