Normal Topic CopySelection from inherited class of control node (Read 2524 times)
Hamdy Ghanem
Jul 21st, 2009 at 9:41am
I have a node class inherited from the control node
I am trying to do copy and past but when I paste it pasts the control node object not my real objected which inherited from the control node
I change the control node to shape node , it works fine
so What is the problem with control node
Re: CopySelection from inherited class of control
Reply #1 - Jul 21st, 2009 at 12:24pm
You should override ControlNode.Clone() to return an instance of your class.
Hamdy Ghanem
Reply #2 - Jul 21st, 2009 at 1:26pm
I did but it take the same control
I think I have to clone also the child control
Reply #3 - Jul 21st, 2009 at 1:37pm
Yes, you must clone the hosted control too. ControlNode.Clone returns a ControlNode instance created using the ControlNode copy constructor. The copy constructor has some code that clones the hosted control, so you could define your copy constructor that calls base, and use it in the Clone override implementation.
Hamdy Ghanem
Reply #4 - Jul 21st, 2009 at 3:03pm
yes thans, it works now
but could I ask another queestion
I have a control node but I need the child control like a button to be as a disabled
not really disable but not just taking event like click
Reply #5 - Jul 22nd, 2009 at 6:16am
You could set ControlNode.ControlMouseAction = ControlMouseAction.IgnoreControl; This works for hosted Buttons, but might not work for controls that capture the mouse.
