Normal Topic ControlMouseAction vs ModificationStart problem (Read 3818 times)
Necroman
Jul 27th, 2009 at 2:54pm
I need AutoHandles behavior - the possibility to move nodes on a first click- click+move does select and instant moving, but if I want to modify some link, that is over a node header or over any other link, focus is switched to underlying control and that something I don't want.
How to do that - instant click+move and not automatic selection of underlying nodes?
thanks
Basically I need onmousedown to cause selection, not mouseover event. Also if any other item is selected and I am clicking on it, no other underlying item should be selected in this case - simple.
Also, is there a method in DiagramView for hittesting if some nodes/links are under current mouse cursor?
Any help will be appretiated.
Re: ControlMouseAction vs ModificationStart proble
Reply #1 - Jul 27th, 2009 at 3:27pm
What happens if you also set HitTestPriority = ZOrder?
Necroman
Reply #2 - Jul 27th, 2009 at 3:47pm
Well, that solved half of my problem, thanks.
The other problem is quite complicated to explain:
Let's have parent node and two child nodes, also two links from parent to child. Both links starts at the same point in parent node. If I select the bottom link an I want to change it's parent location, I cant. Even with ZOrder priority the topmost link is selected?
The ideal priority in my opinion should be
selected objects > objects in z order > bottom
Also SelectionOnTop property is ignored, when I set it to true, strange.
Reply #3 - Jul 27th, 2009 at 4:12pm
We'll change the priority for the next release. Now you might try one of the following:
* handle MouseMove and set ModificationStart = SelectedOnly if diagram.ActiveItem.HitTestHandle() returns some handle index at the current mouse position.
or
* set DiagramLink.HandlesStyle = Custom, handle the HitTestHandles event and return -1 if e.Link is not selected but diagram.ActiveItem is under the mouse pointer.
Necroman
Reply #4 - Jul 28th, 2009 at 9:06am
I've tried these methods, but non of them worked. It looks like the other link is pre-selected(diagram.ActiveItem is changed) when mouse cursor reaches some near distance to it, before I even reach the link node.
I guess the right approach is to keep original link selected, when cursor is near, or when calculating proximity to nearest object keep the selected one on the first position.
Reply #5 - Jul 28th, 2009 at 10:03am
This worked for me:
private void diagramView_MouseMove(object sender, MouseEventArgs e)
	PointF mousePos = diagramView.ClientToDoc(e.Location);
	int activeItemHandle = -1;
	if (diagram.ActiveItem != null)
		diagram.ActiveItem.HitTestHandle(mousePos, ref activeItemHandle);
	diagramView.ModificationStart = activeItemHandle == -1 ?
		ModificationStart.AutoHandles : ModificationStart.SelectedOnly;
Necroman
Reply #6 - Jul 28th, 2009 at 12:07pm
Well, that helped, thanks Smiley
I didn't used the ClientToDoc transformation before...
