Normal Topic Import Visio Diagrams (Read 1721 times)
fglazenburg
Jul 28th, 2009 at 9:14am
Hey,
I would like to import Visio diagrams onto a Mindfusion Diagram. When I call the funciton ImportAllPages I get an XML exception "Data at the root level is invalid. Line 1, position 1.". I used 2002, 2003 and 2007 visio files as import files and I am using the FlowChart.NET 5.3.1 Trial Version binairies.
I use the following code to import a Visio diagram
private void button1_Click(object sender, EventArgs e)
try
vi.ImportAllPages("c:\\SampleChart.vsd", FlowChart);
catch (Exception ex) { }
FlowChartView.Refresh();
FlowChartView.Show();
Does anybody know what the problem might be.
Many thanks.
Frank
fglazenburg
Re: Import Visio Diagrams
Reply #1 - Jul 28th, 2009 at 9:40am
Found the solution. I was importing the vsd files instead of the vdx files.
Frank
Reply #2 - Jul 28th, 2009 at 9:40am
You can import only Visio XML Drawing (*.VDX) files. I think VSD is the Visio binary file format.
