Hot Topic (More than 10 Replies) Databinding Resources (Read 8787 times)
lahai
Jul 28th, 2009 at 7:38am
Hello
I am having issues with getting my calendar to pull the itemcontacts information from a mysql db. I get the items in the single month view however when I switch to resource view and try to group by contacts and show item assigneed to contact I do not get that info. Im sure I am just missing something...
here is the code in my page load:
Private Overloads Sub Form1_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
       Calendar1.Schedule.Clear()
       DataSet1.Clear()
       ReminderTableAdapter1.Fill(DataSet1.reminder)
       StyleTableAdapter1.Fill(DataSet1.style)
       CustombrushesTableAdapter1.Fill(DataSet1.custombrushes)
       ContactTableAdapter1.Fill(DataSet1.contact)
       LocationTableAdapter1.Fill(DataSet1.location)
       ResourceTableAdapter1.Fill(DataSet1.resource)
       TaskTableAdapter1.Fill(DataSet1.task)
       ItemTableAdapter1.Fill(DataSet1.item)
       ItemcontactsTableAdapter1.Fill(DataSet1.itemcontacts)
       ItemresourcesTableAdapter1.Fill(DataSet1.itemresources)
       RecurrenceTableAdapter1.Fill(DataSet1.recurrence)
       RecurrenceexceptionTableAdapter1.Fill(DataSet1.recurrenceexception)
       RecurrenceexceptionsTableAdapter1.Fill(DataSet1.recurrenceexceptions)
       'Calendar1.LoadFromDataSource()
       'Calendar1.BeginInit()
       'Calendar1.Contacts.Clear()
       'Calendar1.Contacts.Add(Calendar1.Schedule.Contacts(0))
       'Calendar1.Contacts.Add(Calendar1.Schedule.Contacts(2))
       'Calendar1.Contacts.Add(Calendar1.Schedule.Contacts(3))
       'Calendar1.Contacts.Add(Calendar1.Schedule.Contacts(4))
       'Calendar1.Contacts.Add(Calendar1.Schedule.Contacts(5))
       'Calendar1.Contacts.Add(Calendar1.Schedule.Contacts(6))
       'Calendar1.Contacts.Add(Calendar1.Schedule.Contacts(7))
       'Calendar1.Contacts.Add(Calendar1.Schedule.Contacts(8))
       'Calendar1.Contacts.Add(Calendar1.Schedule.Contacts(9))
       'Calendar1.Contacts.Add(Calendar1.Schedule.Contacts(10))
       'Calendar1.Contacts.Add(Calendar1.Schedule.Contacts(11))
       'Calendar1.Contacts.Add(Calendar1.Schedule.Contacts(12))
       'Calendar1.Contacts.Add(Calendar1.Schedule.Contacts(13))
       'Calendar1.Contacts.Add(Calendar1.Schedule.Contacts(14))
       'Calendar1.Contacts.Add(Calendar1.Schedule.Contacts(15))
       'Calendar1.Contacts.Add(Calendar1.Schedule.Contacts(16))
       'Calendar1.Contacts.Add(Calendar1.Schedule.Contacts(18))
       'Calendar1.Contacts.Add(Calendar1.Schedule.Contacts(19))
       'Calendar1.Contacts.Add(Calendar1.Schedule.Contacts(17))
       'Calendar1.GroupType = MindFusion.Scheduling.WinForms.GroupType.GroupByContacts
       'Calendar1.EndInit()
    End Sub
Re: Databinding Resources
Reply #1 - Jul 28th, 2009 at 12:16pm
Is there any reason to comment the grouping code or it simply doesn't work as it is now?
lahai
Reply #2 - Jul 28th, 2009 at 2:25pm
I commented it out just to try something new. I can get the contacts in the calendar through that method but not the items.
Reply #3 - Jul 28th, 2009 at 3:14pm
I will test this out and get back to you with any results I might come upon.
Reply #4 - Jul 29th, 2009 at 5:58am
Well, a code similar to the one you commented out seems to be the key to this problem. That is, when you load appointments and contacts back from the data source, you have to instruct the calendar to group by the newly loaded contacts and discard the previous ones:
Dim c as Contact
For Each c In _calendar.Schedule.Contacts
      Calendar1.Contacts.Add(c)
Next
Calendar1.EndInit()
lahai
Reply #5 - Jul 29th, 2009 at 11:50am
Hey meppy,
I added your code and did the same thing for the items however I still dont get the items loaded in the view.
[tr]
Calendar1.Schedule.Items.Clear()
Dim c As MindFusion.Scheduling.Contact
For Each c In Calendar1.Schedule.Contacts
Next
Dim a As MindFusion.Scheduling.Item
For Each a In Calendar1.Schedule.Items
Calendar1.Schedule.Items.Add(a)
Next
Calendar1.EndInit()
[/tr]
Reply #6 - Jul 29th, 2009 at 2:19pm
Below is the complete loading code that works well for me:
DataSet1.Clear()
CustomBrushesTableAdapter1.Fill(DataSet1.customBrushes)
ItemContactsTableAdapter1.Fill(DataSet1.itemcontacts)
ItemResourcesTableAdapter1.Fill(DataSet1.itemresources)
RecurrenceExceptionTableAdapter1.Fill(DataSet1.recurrenceexception)
RecurrenceExceptionsTableAdapter1.Fill(DataSet1.recurrenceexceptions)
Dim c As Contact
Next
Calendar1.EndInit()
Try it at your place and let me know if its working.
lahai
Reply #7 - Jul 29th, 2009 at 2:44pm
No it doesn't. I pull in the contacts fine. Its just the items assigned to those contacts that do not populate the calendar. I can see the items on the other calendar views but not when I go into resource view.  I am running it on a mysql db and have the item contacts table with values in it.
lahai
Reply #8 - Jul 30th, 2009 at 9:56am
Is there any other ideas on this Im at a lose and I am long overdue on delivering this project to my company after it was purchased. Any help is greatly  appreciated...
Reply #9 - Jul 30th, 2009 at 11:30am
Is it possible to send your database and a sample project, which loads the date into the Calendar control, to meppy@mindfusion.eu? I will check here what might be wrong.
lahai
Reply #10 - Jul 30th, 2009 at 9:39pm
Thanks Meppy. I have sent the project to your address.
Reply #11 - Jul 31st, 2009 at 8:21am
I have inspected the project you sent me and the following modifications to the ContactsDataPropertyMap seem to work for me:
(Id) -> Key (instead of (Id) -> Id)
Try this at your place and let me know if there is any improvement. Do not forget to uncomment the code after the LoadFromDataSource call:
Next
Calendar1.EndInit()
lahai
Reply #12 - Aug 2nd, 2009 at 4:09pm
Meppy,
I am still not getting the items in the calendar? have you noticed anything else? Were you running the mysql insert or access?
Reply #13 - Aug 3rd, 2009 at 5:59am
There is one vital thing I forgot to mention about. In your xsd schema (within Visual Studio), you have to establish one-to-many relationship between the following table fields:
[item.Key] <-> [itemcontacts.Item]
[contact.Key] <-> [itemcontacts.Contact]
You can create the relationship by dragging with the mouse from one field to another.
I hope this will help,
lahai
Reply #14 - Aug 3rd, 2009 at 8:31pm
Thanks meppy.
It works now.
