Normal Topic DiagramLinks based on UML shapes (Read 2833 times)
Necroman
Jul 28th, 2009 at 2:39pm
I'm looking for some help how to create basic UML links as DiagramLinks. Is there any table with examples or guide what constructor parameters to use? For example what Pens and Arrow heads to use from the available set?
I guess this is quite common topic and some helper class for creating UML DiagramLinks might be even in MindFusion library Smiley.
Re: DiagramLinks based on UML shapes
Reply #1 - Jul 29th, 2009 at 9:03am
Here is a helper method to create a Generalization connector:
DiagramLink CreateGeneralization(DiagramNode typeNode, DiagramNode baseTypeNode)
	DiagramLink link = diagram.Factory.CreateDiagramLink(typeNode, baseTypeNode);
	link.HeadShape = ArrowHead.Triangle;
	link.CascadeOrientation = Orientation.Vertical;
	link.SegmentCount = 3;
	link.Style = LinkStyle.Cascading;
	link.Brush = new SolidBrush(Color.White);
	PointCollection points = link.ControlPoints;
	RectangleF r1 = typeNode.Bounds;
	RectangleF r2 = baseTypeNode.Bounds;
	points[0] = new PointF(r1.X + r1.Width / 2, r1.Top);
	points[points.Count - 1] = new PointF(r2.X + r2.Width / 2, r2.Bottom);
	link.UpdateFromPoints();
	link.Route();
	return link;
Feel free to use it as a template for the other types Wink
Necroman
Reply #2 - Jul 30th, 2009 at 1:47pm
That look good, thanks.
Another issue I got - I use AlignToGrid diagram property for aligning nodes and links to grid, but still when my diagram is generated and used Arrange method, some links ar elaid out of grid and therefore, if I move these links, I can't move them back to its previous position.
Is there a way how to set up and arrange diagram to be sure, that all links and nodes are really aligned to grid?
Reply #3 - Jul 30th, 2009 at 3:05pm
You could use the AlignPointToGrid method to align items to the grid from code, eg:
PointF p = diagram.AlignPointToGrid(node.Bounds.Location);
node.Move(p.X, p.Y);
