Normal Topic Diagrams appearing when creatin Project (Read 2528 times)
fanderlf
Aug 3rd, 2009 at 7:48am
I've wrote a UserControl containing a FlowChart. Each time I create the UserControl I see an additional diagram instance (diagram1, diagram2...) in the UserControl Designer. However those components seem to just appear in the Designer. They are not added to UserControl.Designer.cs.
Bug or did I miss something?
Greetings,
Fanderlf
Re: Diagrams appearing when creatin Project
Reply #1 - Aug 3rd, 2009 at 8:11am
Are you using the WPF version now?
fanderlf
Reply #2 - Aug 4th, 2009 at 2:18pm
I'm currently using the windows forms version. This just seems to be a designer topic, because they are not added to designer.cs
Reply #3 - Aug 5th, 2009 at 10:18am
Do you mean you are dropping the user control on the form, and a Diagram automatically appears on the control's design area? I could not reproduce that. I can see only what is expected to happen: dropping a DiagramView on the user control automatically creates a Diagram.
