Hot Topic (More than 10 Replies) Scrollbar on TreeViewNode (Read 12390 times)
TimNZ
Aug 10th, 2009 at 11:35pm
Hi Stoyo,
How can I set the internal height of the TreeViewNode so the vertical scrollbar properly reflects the contents.
As you can see in the image, the scrollable area is quite a bit larger than the contents (same issue with Table nodes - would like to stop the table scrolling if no more rows are available to be scrolled into view).
Additionally, the Expandable property is ignored e.g. I can't get the + to display on a TreeViewNode.
Tim
Re: Scrollbar on TreeViewNode
Reply #1 - Aug 11th, 2009 at 1:50pm
Hi Tim,
Check the PM page. The updated version there implements Expandable for TreeviewNodes and should fix the scroll range issue.
TimNZ
Reply #2 - Aug 13th, 2009 at 1:16am
Thanks Stoyo, new dll work as expected.
I'm trying to change the cursor when the mouse is over a TreeViewItem that is underlined.
The only place I can see this being handled is MouseMove, but the event is not called the way I expect at all.
This is my starting point
        private void diagramView_MouseMove(object sender, MouseEventArgs e)
            PointF point = diagramView.ClientToDoc(e.Location);
            DiagramNode diagramNode = diagram.GetNodeAt(point);
            if (diagramNode is TreeViewNode)
                TreeViewNode node = (TreeViewNode) diagramNode;
                TreeViewItem item = node.ItemFromPoint(e.Location);
                if (item != null)
                    TableField tableField = item.Tag as TableField;
                    if (tableField.ForeignTable != null)
                        Cursor.Current = Cursors.Hand;
When the MouseMove event is raised is unpredictable, basically I could move the mouse all over the TreeViewNode, and it never gets to breakpoint on 'TreeViewNode node = ...'
TimNZ
Reply #3 - Aug 13th, 2009 at 2:16am
Ok, event does work as expected, but setting DiagramView.Cursor or DiagramView.CurrentCursor does not change cursor.
Reply #4 - Aug 14th, 2009 at 10:07am
Try setting diagramView.DrawLinkCursor.
TimNZ
Reply #5 - Aug 14th, 2009 at 10:32pm
Hi Stoyan,
Thanks for the tip, it turned out I needed to set PointerCursor for what I want to achieve (simulate a hyperlink on just the underlined nodes).
Tim
madhan1
FOLLOW NO ONE BUT LEARN
FROM EVERY ONE ..
Reply #6 - Feb 17th, 2010 at 7:39am
where can i find the new dll ?
if you want something then go and grab it
Reply #7 - Feb 17th, 2010 at 9:45am
We have already had a couple of releases since this thread was started. Have you found a similar issue in the latest version?
madhan1
FROM EVERY ONE ..
Reply #8 - Feb 17th, 2010 at 9:57am
yes.. still i didn't have the scroll bar. my treelayout is very big each node has atleast 5 child up to 5 levels...
Reply #9 - Feb 17th, 2010 at 10:03am
Call diagram.ResizeToFitItems after applying TreeLayout.
madhan1
FROM EVERY ONE ..
Reply #10 - Feb 17th, 2010 at 10:12am
Thanks for your reply. But my requirement is to expand only my current node not child and sub child node.
Reply #11 - Feb 17th, 2010 at 10:24am
By "TreeLayout" don't you mean you have some nodes connected in a tree, and wish to expand the diagram area after calling TreeLayout.Arrange?
madhan1
FROM EVERY ONE ..
Reply #12 - Feb 17th, 2010 at 10:42am
mmmmmm....when i click the expand (+) button i want to expand only that node not the subchild
Reply #13 - Feb 17th, 2010 at 10:51am
Set diagram.RecursiveExpand = false if you have a tree of Expandable nodes, and not TreeViewNodes this thread was about.
madhan1
FROM EVERY ONE ..
Reply #14 - Feb 17th, 2010 at 10:58am
Stoyan thanks a lot... your so great  Cheesy
