Normal Topic Inaccurate Visio Import (Sequence Diagram) (Read 2302 times)
cryo
Feb 20th, 2010 at 6:08am
The sequence diagram's links defined in the visio file (*.vdx) are not imported correctly in MindFusion. If I use a Message, Message call or a Message return link, they are replaced by shape nodes in MindFusion after importing.
I am using Visio importer version 5.3.1.27103
Is there a fix/workaround for this? (e.g. during runtime, after importing, can I manually replace the incorrect shape nodes with my custom links, provided these nodes are tagged somehow)
Re: Inaccurate Visio Import (Sequence Diagram)
Reply #1 - Feb 20th, 2010 at 11:41am
Handle the ShapeImported event to process shapes that are not recognized by VisioImporter. The event args object contains ShapeName and ShapeXml properties that provide information about the imported shape. You can find some sample code here:
http://mindfusion.eu/Forum/YaBB.pl?board=fcnet_disc;action=display;num=120835901...
