Hot Topic (More than 10 Replies) Scrollbar on TreeViewNode (Read 11155 times)
madhan1
FOLLOW NO ONE BUT LEARN
FROM EVERY ONE ..
Re: Scrollbar on TreeViewNode
Reply #15 - Feb 17th, 2010 at 11:03am
But Stoyan still i din't get the Horizontal scroll bar.... ???
if you want something then go and grab it
Reply #16 - Feb 17th, 2010 at 11:07am
Handle the TreeExpanded event and call diagram.ResizeToFitItems from the handler.
madhan1
FROM EVERY ONE ..
Reply #17 - Feb 17th, 2010 at 11:24am
Quote:
private void diagram_TreeExpanded(object sender, NodeEventArgs e)
rearrange();
           diagram.ResizeToFitItems(8,true);
but still i didn't get the scroll bar Sad
madhan1
FROM EVERY ONE ..
Reply #18 - Feb 17th, 2010 at 11:36am
like this only i am geting...
Reply #19 - Feb 17th, 2010 at 12:44pm
Are you sure DiagramView.ShowScrollbars is enabled?
madhan1
FROM EVERY ONE ..
Reply #20 - Feb 18th, 2010 at 3:49am
yes. i have enabled. the scroll bar is showing but i cann't see the full tree.... as i send the image before.......
Reply #21 - Feb 18th, 2010 at 8:23am
Do you mean you want the full tree to be visible at once without having to scroll it? Try the ZoomToFit method in such case. Otherwise please email to support@mindfusion.eu a sample project that shows your problem.
madhan1
FROM EVERY ONE ..
Reply #22 - Feb 19th, 2010 at 10:19am
Thanks Stoyan.
