Normal Topic XML Database (Read 2557 times)
ggiuliano
New is Me...
XML Database
Aug 17th, 2009 at 8:01am
Hi All,
New member and been playing around with VB.net.
I have created program that reads an xml database, database tables exported from access (to XML), 6 tables that link together by a job number.
Each table was exported so I now have six XML files.
I have been making amendments to the xml file by opening in WordPad and editing, for me to finish the xml database I have to link the XML files in one big XML file, however WordPad seems to have a maximum file size limit 34MB.
Question is does anyone know of a software for me to use that does not have a XML editing file size limit...?
The XML database size will be around 60-70MB so I will need an XML editing software that can open and edit this file size.....
Unless there is an easier way that some one can point me in the right direction....
Cheers, this will be a great help...
Smiley
GG
Re: XML Database
Reply #1 - Aug 17th, 2009 at 9:30am
Try this tool:
http://www.netlegger.net/largeedit.asp
ggiuliano
New is Me...
Re: XML Database
Reply #2 - Sep 1st, 2009 at 4:25pm
Thanks stoyan... Smiley
Used the largeedit and worked great... pity its not open source as I am sure it would prove useful in the future....
