Normal Topic NetDiagram Import/Export Picture format (Read 3179 times)
123danian
Sep 1st, 2009 at 12:38am
Hi, under  Asp.net 3.5 ,i will do import/export  pictures in NetDiagram; i  know only .viso format,
but i hope someone  can  tell me exactly how many picture formats  can be exported/imported from / to NetDiagram View control;
More thanks for his/her giving some detailed materials or some PDF documents...?
Re: NetDiagram Import/Export Picture format
Reply #1 - Sep 1st, 2009 at 7:10am
You can also export to SVG, PDF, DXF and bitmap image format such as PNG and JPEG. See the "Exporting the Diagram" topic in the help file.
123danian
Reply #2 - Sep 2nd, 2009 at 12:31am
Thank you , you so expert Smiley
