Hot Topic (More than 10 Replies) Action required on Anchor point. (Read 10289 times)
Re: Action required on Anchor point.
Reply #15 - Sep 23rd, 2009 at 1:16pm
Do you need to allow creating links only when the user starts drawing over an anchor point? I think we did that some time ago using a custom Behavior class.
Anshul
Senior Member
Reply #16 - Sep 23rd, 2009 at 1:19pm
Yes right, we did this some time before, it is working well in the condition when node is not selected but if the node is selected anchor point comes on mouse move but we are not able to create link in this condition.
We want to draw link from the anchor point even if the node is selected.
Anshul
Reply #17 - Sep 24th, 2009 at 7:55am
The base implementation always starts moving or resizing the node if a handle of a selected node is hit. You might move the code that hit-tests for anchor points to a separate method, call it from your diagram_HitTestAdjustmentHandles handler, and if it returns a point, set HitResult to -1. This seems to work fine in the "Anchor point Action" project you sent us some time ago.
internal static AnchorPoint GetAnchorAt(DiagramNode node, Point point)
	foreach (AnchorPoint ap in node.AnchorPattern.Points)
		Rect r = node.Bounds;
		Point p = new Point(
			r.Width * ap.X / 100 + r.X,
			r.Height * ap.Y / 100 + r.Y);
		if (MindFusion.Utilities.Distance(p, point) < 10)
			return ap;
	return null;
// in the HitTestAdjustmentHandles handler
if (n.AnchorPattern != null && DrawLinkAtAnchorBehavior.GetAnchorAt(n, e.MousePosition) != null)
	e.HitResult = -1;
	return;
Anshul
Senior Member
Reply #18 - Sep 24th, 2009 at 11:36am
Thanks Stoyan, its working now Smiley
