Normal Topic FlowChart.NET 5.3.1 Arrows messed (Read 2320 times)
Vivekagarwal
Aug 18th, 2009 at 3:33pm
I am in process of upgrading to FlowChart.NET 5.3.1. I have a schematics screen where screen shows radial layout based on "In" and "Out" source. The arrows were working fine with FlowChart.NET old version and was showing correct flow but after I upgraded to new version. screen is messed up. All child nodes are displayed at top of the screen which doesn't look into the correct layout. Here is the code where I am changing Parent and child for show IN and OUT arrows. Can you help me how to keep nodes in correct layout.
               Dim Arrow As DiagramLink
               If flowDir = "INPUT" Or flowDir = "INPUT_CHECK" Then
                   Arrow = flowchart.Factory.CreateDiagramLink(childBox, parentBox)
               ElseIf flowDir = "OUTPUT" Or flowDir = "OUTPUT_CHECK" Then
                   Arrow = flowchart.Factory.CreateDiagramLink(parentBox, childBox)
               Else
               End If
Re: FlowChart.NET 5.3.1 Arrows messed
Reply #1 - Aug 18th, 2009 at 4:13pm
Could you email us a sample diagram of yours saved as xml file?
Vivekagarwal
Reply #2 - Aug 18th, 2009 at 4:41pm
I sent you an email with details.
Reply #3 - Aug 18th, 2009 at 5:17pm
What does your layout code look like? If you have links pointing in both directions, you should set the TreeLayout.IgnoreLinkDirection property and specify which node is TreeLayout.Root - have you done that?
Vivekagarwal
Reply #4 - Aug 18th, 2009 at 5:36pm
Ok, that worked. Thanks for all your help.
