Normal Topic How to manage custom properties for a shape? (Read 1650 times)
vicmart69
Aug 28th, 2009 at 8:42pm
I am using workflow to generate sequence of events, and those events will be stored in a database.
1) What is the best way to manage custom properties (ie: each shape will represent a specific activity with a server name, DB name....)
2) Is there a way to save the diagram along with these custom properties in a single shot? In readable format?
MA
« Last Edit: Aug 28th, 2009 at 11:48pm by vicmart69 »
Re: How to manage custom properties for a shape?
Reply #1 - Aug 30th, 2009 at 7:18am
1) You could define a class that contain the custom properties, and assign its instances to the Tag property of items. This is useful if you need the same properties attached to several item types. If you need them for just one type of items, e.g. ShapeNode, you could derive from it and add new properties to the class declaration.
2) You might save it to XML by calling diagram.SaveToXml() or SaveToString(StringFormat.Xml). If the properties are stored as Tag values, handle the SerializeTag event to add custom Xml element to the node element.
vicmart69
Reply #2 - Aug 31st, 2009 at 3:48pm
Just like magic!!
Thanks.
MA
