Normal Topic Routing and Layout with 5.3.1 (Read 1187 times)
cbh
Sep 3rd, 2009 at 9:53am
I have upgraded from version 4.x to 5.3.1 and I noticed many changes in routing and layout classes and options.
I 'm using Bezier style for links and TreeLayout.
After Upgrade behavior is quite different for routing and Layout.
I' ve changed Diagram's LinkRouter to a GridRouter and routing is closer to 4.x routing.
I 've red documentation and some information are missing:
When RoutingOptions are involved ? (QuickRouter, LinkRouting, AutoRoute, used with Layout ?)
What means values for cost members, what is impact if I increase or decrease value ?
In fact I was using TreeLayout then a custom algorythm to have same result as new FlowChartLayout but with Rounded link, will rounded links be supported for FlowChartLayout in upcoming version ?
I have also noticed 2 bugs:
In Diagram Properties, when you set LinkRouter to "(none)" (Diagram.LinkRouter = null in InitializeComponent) a crash occurs when adding first shape into diagram.
With a diagram with handred of shapes, PathFinder.FindLongestPath can loop and memory can't stop increasing.
Thanks for Help.
CBH.
Re: Routing and Layout with 5.3.1
Reply #1 - Sep 3rd, 2009 at 10:29am
The costs in RoutingOptions are used only by GridRouter, so auto-routed links are affected by RoutingOptions values when diagram.LinkRouter is set to a GridRouter instance. In fact we plan to merge most of RoutingOptions into GridRouter, and move the remaining properties into Diagram (e.g. TriggerRerouting).
GridRouter evaluates many paths by summing the costs associated with every bend, crossing or length unit in the path (TurnCost/CrossingCost/LengthCost). From the found paths, it chooses the one with lowest total cost.
I guess we'll get to this at some point, but can't guarantee when we'll implement it. At this time you could enable diagram.RoundedLinks to get a similar effect, even with polyline and cascading links.
