Hot Topic (More than 10 Replies) LayeredLayout problem (Read 11307 times)
Re: LayeredLayout problem
Reply #15 - May 3rd, 2010 at 2:24pm
If all nodes have at least one strong link connection, try setting IgnoreLayout = true for the weak links and routing them after the layout. If there are some nodes linked to the graph only through weak links, you might try some combination of layouts where a node from the hierarchy and its weak-linked nodes are arranged and grouped independently, and then treated as a single node in a higher-level layout via the KeepGroupLayout property.
Necroman
Reply #16 - May 3rd, 2010 at 8:11pm
Sounds complicated, but I'll give it a try Smiley
Necroman
Reply #17 - May 4th, 2010 at 9:10am
How to treat group of nodes, with weak links, in layout as a single node - maintain the layout within the group?
Reply #18 - May 4th, 2010 at 10:58am
Yes, attach them to a node from the hierarchy and run a layout with KeepGroupLayout enabled.
