Normal Topic Is there a caption with WinForms shapes (Read 1346 times)
chuckdawit
Sep 8th, 2009 at 10:43pm
Is there a caption and text fields with WinForms shapes like with ASP below:
Diagram diagram = new Diagram();
TableNode t = diagram.Factory.CreateTableNode(0, 0, 50, 30);
t[0, 0].Text = "Pairs Model 1212";
t.Caption = "S1";
Re: Is there a caption with WinForms shapes
Reply #1 - Sep 9th, 2009 at 5:55am
Yes, TableNode is implemented by mindfusion.diagramming.dll, which is used both in the Windows Forms and ASP.NET versions of the control. Add to your project a reference to that dll, add a using/import statement for the MindFusion.Diagramming namespace, and you should be able to use TableNodes.
