Normal Topic lightweight diagram XML (Read 2440 times)
asafs
Sep 17th, 2009 at 4:41am
I'm trying to save a lighter xml of the diagram with only the critical attributes . for instance I want to save for a link only it's origin, destination and location. all other features are set when the diagram is loaded and never changed. I want to persist the diagram XML to a database and keep it small and light.
Is there a way to do that?
Asaf
Re: lightweight diagram XML
Reply #1 - Sep 17th, 2009 at 2:03pm
Try this:
XDocument document = new XDocument();
SaveLightXml(diagram, document);
diagram.ClearAll();
LoadLightXml(diagram, document);
private void SaveLightXml(Diagram diagram, XDocument document)
	XmlPersistContext context = new XmlPersistContext(diagram, document);
	XElement root = new XElement("Diagram");
	document.Add(root);
	XElement nodesEl = context.AddChildElement("Nodes", root);
	foreach (DiagramNode node in diagram.Nodes)
		ShapeNode shapeNode = node as ShapeNode;
		XElement nodeEl = context.AddChildElement("Node", nodesEl);
		nodeEl.SetAttributeValue("Id", shapeNode.ZIndex);
		context.WriteRectangleF(shapeNode.Bounds, "Bounds", nodeEl);
		context.WriteString(shapeNode.Text, "Text", nodeEl);
	XElement linksEl = context.AddChildElement("Links", root);
	foreach (DiagramLink link in diagram.Links)
		XElement linkEl = context.AddChildElement("Link", linksEl);
		context.WriteInt(link.Destination.ZIndex, "Destination", linkEl);
		context.WriteInt(link.Origin.ZIndex, "Origin", linkEl);
private void LoadLightXml(Diagram diagram, XDocument document)
	XElement root = document.Root;
	Dictionary<int, ShapeNode> dictionary = new Dictionary<int, ShapeNode>();
	XElement nodesEl = root.Element("Nodes");
	var nodeElements = nodesEl.Elements("Node");
	foreach (XElement nodeEl in nodeElements)
		ShapeNode node = diagram.Factory.CreateShapeNode(10, 10, 10, 10);
		int id = int.Parse(nodeEl.Attribute("Id").Value);
		node.Bounds = context.ReadRectangleF("Bounds", nodeEl);
		node.Text = context.ReadString("Text", nodeEl);
		dictionary.Add(id, node);
	XElement linksEl = root.Element("Links");
	var linkElements = linksEl.Elements("Link");
	foreach (XElement linkEl in linkElements)
		int dest = context.ReadInt("Destination", linkEl);
		int orig = context.ReadInt("Origin", linkEl);
		ShapeNode destNode = dictionary[dest];
		ShapeNode origNode = dictionary[orig];
		diagram.Factory.CreateDiagramLink(origNode, destNode);
asafs
Reply #2 - Sep 17th, 2009 at 5:58pm
Wow!
Thanks for the quick and helpful reply, I'll try your code.
Thanks alot Stoyan !!!
