Normal Topic Undo/Redo in Lane Diagrams (Read 2056 times)
David Long
Sep 18th, 2009 at 1:36pm
Is it possible to store changes to the Lane Grid in the Undo history?
Changes such as:  insert column, delete column, insert row, delete row, change row/column width, change header text.
DavidL
Re: Undo/Redo in Lane Diagrams
Reply #1 - Sep 18th, 2009 at 2:27pm
You could create a class derived form Command that implements the Execute, Undo and Redo method by doing the required LaneGrid modifications. Then when you must change the grid, call the Diagram.ExecuteCommand method, passing an instance of your class as an argument.
David Long
Reply #2 - Sep 18th, 2009 at 3:13pm
Yes, that does help.  I've done exactly that for changes to a ShapeNode's Tag data that I wish to undo/redo.
Will the undo/redo of Grid properties be included in a future release of the product?
David
Reply #3 - Sep 19th, 2009 at 10:46am
I'll add this to our todo list, but can't vouch for any release date.
