Normal Topic Nothing appears in OutgoingLinks (Read 1685 times)
bradaisa
Sep 23rd, 2009 at 4:30pm
I have this code:
                link = diagram.Factory.CreateDiagramLink( _
                  selNode, otherRef.Table, otherRef.RowIndex)
where selNode is a TableNode
When I step through the code, the call works, and the link is created, but the selNode.OutgoingLinks.Count remains at 0 --
In the GUI I see the link from the selNode Table to the otherRef table row. But it seems to not be present in the links collection of selNode -- the problem is that I need to be able to later delete it, but can't find it. Thanks for any tips!
Re: Nothing appears in OutgoingLinks
Reply #1 - Sep 23rd, 2009 at 5:29pm
Try setting selNode.ConnectionStyle to Table before creating the link. Otherwise the link is probably connected to some row and you can find it in the row's OutgoingLinks collection. You could also call the GetOutgoingLinks() method to get a list of all links connected either to the table or its rows.
bradaisa
Reply #2 - Sep 23rd, 2009 at 5:34pm
This worked, thanks! I was able to set it to Table in code and was still able to make Row links in code (as I wanted.)
