Normal Topic Anchor is not working (Read 1642 times)
ayushneema
Sep 26th, 2009 at 1:59pm
I have created a diagram that consists of some shape node. I am creating links between these node from anchor points. linkes creation working fine untill i don't select node. when i "select any node" and try to create link node is also start moving with cursor so i am unable to create link.
so how can i create link from selected node.
Ayush Neema
Re: Anchor is not working
Reply #1 - Sep 27th, 2009 at 11:20am
It depends on the HandlesStyle of nodes how easy it is to create a link from a selected node. E.g. SquareHandles lets you draw links from any point of the node apart from where the square handles are located. You could also handle HitTestAdjustmentHandles and set args.HitResult = -1 to allow drawing links from the current point.
ayushneema
Reply #2 - Sep 28th, 2009 at 4:39am
Hi stoyo
Thanks for reply,
I am setting the HitResult=-1.
thanks once again
