Normal Topic How to use the QuickRouter? (Read 1364 times)
chris
Sep 28th, 2009 at 7:18pm
Hi Stoyan,
How can I use the QuickRouter in Version 2.2.1?
Is it default for a Diagram control to arrange link router so it is used by default?
Thanks a lot!
Re: How to use the QuickRouter?
Reply #1 - Sep 29th, 2009 at 5:31am
Hi Chris,
It is used by default now for auto-routed links and by the RouteAllLinks method. You can revert back to the old router by setting diagram.LinkRouter = new GridRouter(), if you need to.
