Normal Topic how to implement fad in-fad out effect. (Read 2151 times)
ayushneema
Sep 29th, 2009 at 12:19pm
how can i implement fad in -fad out effect on window. i want that when i hover mouse any node  a window should appear with "fad in" effect.  and when i remove mouse from the node window disappear with fad out effect.
Ayush Neema
Re: how to implement fad in-fad out effect.
Reply #1 - Sep 29th, 2009 at 3:47pm
You might run an animation on the window's Opacity property.
ayushneema
Reply #2 - Oct 1st, 2009 at 12:01pm
Hi stoyo,
could you please explain more about it.
Ayush Neema
Reply #3 - Oct 2nd, 2009 at 8:15am
The following sample will give you an idea:
https://mindfusion.eu/_samples/_sample_FadeInAnim.zip
You might have to fix the references to your local diagramming assemblies.
