Normal Topic Unable to move node before resizing (Read 1811 times)
ayushneema
Sep 29th, 2009 at 4:23pm
hi
i am creting a node using follwing code:
ShapeNode mainNode = new ShapeNode(diagram);
int height = 30;
int width = 30;
var format = new StringFormat();
                format.Alignment = StringAlignment.Center;
                format.LineAlignment = StringAlignment.Far;
                format.FormatFlags = StringFormatFlags.NoWrap;
                format.Trimming = StringTrimming.EllipsisCharacter;
                mainNode.EnableStyledText = true;
                mainNode.PolygonalTextLayout = false;
                mainNode.TextFormat = format;
                mainNode.ClipToBounds = true;
                mainNode.AnchorPattern = null;
                mainNode.HandlesStyle = HandlesStyle.SquareHandles | HandlesStyle.EasyMove;
                mainNode.EnabledHandles = AdjustmentHandles.ResizeHandles | AdjustmentHandles.Move;
                diagram.Nodes.Add(mainNode);
mainNode.Shape = stickyNoteShape;
                height = note.ObjectHeight;
                width = note.ObjectWidth;
                if (width == 30)
                    width += note.XPos;
                    height += note.YPos;
                mainNode.Bounds = new Rect(new Point(note.XPos + xOffset, note.YPos + yOffset)
                        , new Size(width - note.XPos, height - note.YPos));
                mainNode.Brush = new SolidColorBrush(Color.FromArgb(95, 211, 211, 211));
                mainNode.Pen = new Pen(new SolidColorBrush(Color.FromRgb(189, 186, 105)), 1);
                Uri uri = new Uri(App.GetImagesPath() + Image
                mainNode.Image = new BitmapImage(uri);
                mainNode.ImageAlign = ImageAlign.TopLeft;
                mainNode.Text = note.NoteName;
                mainNode.TextBrush = Brushes.Black;
                mainNode.ZIndex = 0;
but i am unable to move after selecting.
but when i resize it i am able to move it.
please provide the valuable suggestion
Ayush Neema
Re: Unable to move node before resizing
Reply #1 - Sep 29th, 2009 at 7:28pm
HandlesStyle is not a flags enum and SquareHandles | EasyMove is not an expected value, though it works accidentally with the code passing through various "else" blocks...
In the handles style you are getting as end result, there is a few millimeters area near the borders that allows creating links, but if the node is very small, the link creation area covers all of it. You could set the node to be larger initially and moving it will work. However, better set HandlesStyle to Custom and handle the Draw/HitTestHandles events, because this that combination might stop working in some future version.
ayushneema
Reply #2 - Oct 1st, 2009 at 11:07am
it's working .. Cheesy
thanks stoyo
