Normal Topic Changing Handle Outline Color (Read 1914 times)
jakepratt
Oct 1st, 2009 at 2:08am
I am evaluating Flowchart.NET and have figured out most of what i need to do....the only thing i am stuck on is how do i change the color of the Selection Handles on a node.  I know how to change the fill color of the handles but the outline is black and i want it in a light blue.     Is there a property to change this color (pen color?) or do i have to take over the drawing of the handles completely to get the color i am needing?
Re: Changing Handle Outline Color
Reply #1 - Oct 1st, 2009 at 7:57am
There's no property for this. We can add one for the next release - until then you could set the HandlesStyle to Custom and handle the DrawAdjustmentHandles and HitTestAdjsutmentHandles events.
jakepratt
Reply #2 - Oct 1st, 2009 at 1:11pm
Awesome....that would be great.
Reply #3 - Oct 5th, 2009 at 12:03pm
https://mindfusion.eu/_beta/fcnet_handlespen.zip
This version adds the ActiveItemHandlesStyle, SelectedItemHandlesStyle and DisabledHandlesStyle properties used instead of the respective *Color properties. The Style objects have a HandlePen subproperty you could use to change the handles pen color. The HandleBrush subproperty lets you set the fill. There are also members that let you change the hatch and dash brushes used with some HandlesStyle values.
PS. The Color properties are still there but are not used anymore and we'll remove them from the released version.
