Hot Topic (More than 10 Replies) Enter Data (Read 6083 times)
gurram
Enter Data
Oct 1st, 2009 at 2:10pm
Hi
I am using mindfusion for my flowchart in asp.net
for that i am using netdiagraming
i am running flowcharter from samples..so i am using that.
my question is wheni drap and drop a circle,i want enter name of that circle as cirlce1.but how can i enter text
second question if it YES condition i am going to another shape if NO condition remains same..HOw can i dispaly text like yes  and noat the top of the arrows
kalyan
Re: Enter Data
Reply #1 - Oct 2nd, 2009 at 8:02am
1. You could call DiagramView.beginEdit(args.getNode()) from the NodeCreatedScript. For example check the PdfExporter sample project.
2. Call DiagramLink.setText().
gurram
Re: Enter Data
Reply #2 - Oct 6th, 2009 at 2:37pm
i am using
 var node = args.getNode();
	  node.setText("edit me!");
	  <%=diagramView.AppletElement%>.getDiagramView().beginEdit(node);
.i am getting these from pdfexporter samples..how can i increse font and its colour
2:DiagramLink.setText();;;
can you give some example where i can call  this method ..any example will be appriciated
gurram
Re: Enter Data
Reply #3 - Oct 6th, 2009 at 3:37pm
one more question stoyo
iam using  ModificationStart="AutoHandles" in ndiagramview
so after selecting node if i enter delete button the node will deleted..but is it possible to popout window  "are you sure you want delete yes or no "when the time of delete..can you give sample code or any example
Thanks for your time
Re: Enter Data
Reply #4 - Oct 6th, 2009 at 3:43pm
Try this:
<DiagramView NodeDeletingScript = "onNodeDeleting" ... >
function onNodeDeleting(sender,args)
	if (!confirm('Are you sure?'))
		args.setCancel(true);
Re: Enter Data
Reply #5 - Oct 7th, 2009 at 5:38am
Regarding the previous questions, you could do the following:
node.setFont(scriptHelper.createFont(fontName, fontSize));
node.setTextColor(scriptHelper.createColor(r, g, b));
You can set the LinkText property to have some default text for new links, and later call setText() in response to some UI events on the client side, e.g. from the LinkModifiedScript.
gurram
Re: Enter Data
Reply #6 - Oct 7th, 2009 at 2:46pm
Hi stoyo
is it possible to get nodetype.
for example if i have 3 nodes
start,decision,terminator..
when i double click on a node it will oepn a new window.i want like this will occur only for decision node ..i dont want to this for start node and terminator node
for that i think i  need node type for example decision, process...can you give some expamle or code how can i get node type also.
Re: Enter Data
Reply #7 - Oct 8th, 2009 at 7:22am
Check the ID of the node's Shape:
if (args.getNode().getShape().getId().equals('Decision'))
     openWindow();
gurram
Re: Enter Data
Reply #8 - Oct 8th, 2009 at 1:51pm
   HI ,
      I was used which you have sent the code in nodedoubleclicked event
function onNodeDoubleClicked(sender, args)
if (args.getNode().getShape().equals('Decision'))
     confirm_delete();
function confirm_delete()
if (confirm("IF you want to Create the page Press Ok Otherwise to Edit press Cancel?")==true)
   myRef = window.open('Add.aspx','mywin','left=20,top=20,width=500,height=500,toolbar=1,re
sizable=0');
else
   myRef = window.open('Edit.aspx','mywin','left=20,top=20,width=500,height=500,toolbar=1,r
esizable=0');
<ndiag:DiagramView ID="diagramView" runat="server" Style="left: -1px; width: 1000px;
           position: absolute; top: 13px; height:550px"
           NodeDoubleClickedScript="onNodeDoubleClicked" NodeCreatedScript="onNodeCreated"
</ndiag:DiagramView>
Actually Iam using the confirm Message when decision node is double clciked.But iam not getting the confirm message box.Can You please suggest me in the code.
Re: Enter Data
Reply #9 - Oct 8th, 2009 at 2:14pm
I think you've missed the getId() call after getShape().
gurram
Re: Enter Data
Reply #10 - Oct 8th, 2009 at 2:41pm
     I used the getid() still not gettting the confirm message box.
function onNodeClicked(sender, args)
     if (args.getNode().getShape().getId().equals('Start'))
     confirm_delete();
sizable=0');
else
esizable=0');
Re: Enter Data
Reply #11 - Oct 8th, 2009 at 4:32pm
This should work:
if (args.getNode().getShape().getId() == 'Start')
gurram
Re: Enter Data
Reply #12 - Oct 8th, 2009 at 4:39pm
Great, it's working..
i have one more question..is it possible to chane shape names..that means..if i have a shape in shapelist box named circle beside of it. can i chaneg the name for that shape..for cirlce i want to ginve name workstation1  and for Decision i want to give name work station2..how can get this .please send me somecode
Thanks you so much
Re: Enter Data
Reply #13 - Oct 8th, 2009 at 4:49pm
I think the listbox displays the string returned by Shape.DisplayName property, which by default is the same as the shape id. You could change a shape's display name on the client side like this:
Shape.fromId("Decision").setDisplayName("station2");
Do that before adding the shapes to the listbox, or otherwise also call the invalidateShapeAt() method.
