Normal Topic Enable Right Click Context Menu (Read 1389 times)
Dimah
May Peace Be Upon you...
Oct 8th, 2009 at 3:20pm
Hi
Can you pls post sample code for enabling the right click of the each custom shape node to populate the context menu and how to trigger the event for the each menu.
PDM.
Re: Enable Right Click Context Menu
Reply #1 - Oct 8th, 2009 at 4:35pm
E.g. the DirTree sample project displays a context menu like this:
private void dirDiagram_NodeClicked(object sender, NodeEventArgs e)
	if (e.MouseButton != MouseButton.Right)
		return;
	// display context menu at right mouse click
	currentFolder = e.Node as ShapeNode;
	cmFolder.Show(this, PointToClient(MousePosition));
