Normal Topic Offset in ClientToDoc (Read 2344 times)
oOAnriOo
Nov 18th, 2009 at 10:28am
I'm trying to determine wether an object is dragged over a diagramnode. For that I use the code below.
Problem is; using the code below, the background changes to yellow a bit BEFORE I hit the object and back to white a bit BEFORE i exit the object.
It seems to me that the ClientToDoc is off by a small amount..
If I set an anchorpoint in each corner of my node, they show as expected, but still the drag-position doesn't quite hit the spot.
What am I missing?
Quote:
protected override void OnDragOver(DragEventArgs drgevent)
Point pt = this.PointToClient(Cursor.Position);//new Point(drgevent.X, drgevent.Y));
PointF lDragPosition = this.ClientToDoc(new Point(pt.X,pt.Y));
foreach (MindFusion.Diagramming.DiagramNode iNode in this.Diagram.Nodes)
if (iNode.Bounds.Contains(lDragPosition))
iNode.Brush = new MindFusion.Drawing.SolidBrush(Color.Yellow);
else
iNode.Brush = new MindFusion.Drawing.SolidBrush(Color.White);
base.OnDragOver(drgevent);
oOAnriOo
Re: Offset in ClientToDoc
Reply #1 - Nov 18th, 2009 at 10:42am
Well.
This turned out not to be a problem with the MindFusion components.
The hotspot on my pointer is off when it enters my application..   I think its a Windows 7/Aero bug simce it works fine on other computers.
