Normal Topic Problem with attached nodes (Read 1176 times)
pifor106
Nov 19th, 2009 at 5:00pm
I have a simple problem which I'm unable to fix. I'm quite new with Mindfusion and I'm trying to do something which I think should be easy but can't find how.
I have two nodes.
I have attached the second node to the first node. Both are ShapeNodes. However, for my attached node to be showed, the parent node must be selected. I have tried looking at the documentation to find what's wrong but can't seem to find it.
Any help is welcome
Re: Problem with attached nodes
Reply #1 - Nov 19th, 2009 at 5:41pm
Call the child node's ZTop method, after both nodes have already been added to the diagram.
