Normal Topic Node unselect problem (Read 2135 times)
Anshul
Senior Member
Oct 12th, 2009 at 3:33pm
Hi Stoyan,
If I click on node, it get selected.
If I click again , it still remain selected.
I want behavioure to be, node should get unselected when I click again.
Is there any property provided by MindFusion to do that?
Please suggest for this.
Anshul
Re: Node unselect problem
Reply #1 - Oct 12th, 2009 at 5:41pm
No, but there is the Ctrl key Roll Eyes
Anshul
Senior Member
Reply #2 - Oct 12th, 2009 at 6:48pm
Hi Stoyan,
Suppose I have 3 selected nodes. If I press control key and than click on any selected node than instead of unselect the node, it makes that node as active node of the diagram, so use of control key is no use.
I want to perform unselect node while click on selected node again.Please suggest what I could do?
Is there any work around for the same?
Please suggest.
Anshul
Reply #3 - Oct 12th, 2009 at 7:03pm
To avoid using Ctrl, you can handle the validation NodeSelecting and Deselecting events and set e.Cancel = true, and then from the Clicked event call diagram.Selection.Toggle(e.Node).
Anshul
Senior Member
Reply #4 - Oct 13th, 2009 at 1:52pm
Thanks Stoyan Smiley
