Normal Topic LinkValidationEventArgs error on a straight link (Read 1757 times)
billcch
Oct 15th, 2009 at 12:45am
LinkModifying question:
I am using DiagramLinks to connect TableNodes. When user drags an arrow HEAD (connect to destination table), if the link contains at least one segment, it works well, however, if there is no segment in the link, on the event of diagram1_LinkModifying, the LinkValidationEventArgs "e" contains the following weird values:
e.AnchorIndex = -1
e.ChangingDestination = false
e.ChangingOrigin = false
e.Node= null
e.TableRow = -1
If I tried to generate a segment on the same link in the diagrm (ex: moving the destination tableNode), then it works. Again, changing the link back to a straight line (no segment), the problem occurs.
BTW: I am using FlowChart.Net Pro 5.1.1
Re: LinkValidationEventArgs error on a straight li
Reply #1 - Oct 15th, 2009 at 9:26am
I suppose you would get such values when dragging an intermediate control point rather than one at the end. If you are using Cascading links, this might happen if SegmentCount == 2; then the last two points could overlap and grabbing a handle at the link's end might select the one for the intermediate point. Try setting SegmentCount = 3 to move the intermediate points to the middle of the link.
billcch
Reply #2 - Oct 15th, 2009 at 4:35pm
I did set link.SegmentCount = 3, but it seems not working, after I apply the layout, it changed back to 2.
link.Pen.Color = linkInfo.LineColor;
link.Brush = new MindFusion.Drawing.SolidBrush(linkInfo.FillColor);
link.ShadowOffsetX = 0;
link.ShadowOffsetY = 0;
link.HeadShape = ArrowHead.Triangle;
link.HeadShapeSize = 4;
link.BaseShape = ArrowHead.RevTriangle;
link.BaseShapeSize = 4;
link.HandlesStyle = HandlesStyle.MoveOnly;
link.Style = LinkStyle.Cascading;
link.SegmentCount = 3;
link.DrawCrossings = true;
link.Dynamic = true;
link.SnapToNodeBorder = true;
MindFusion.Diagramming.Layout.LayeredLayout layout = new MindFusion.Diagramming.Layout.LayeredLayout();
layout.Anchoring = Anchoring.Reassign;
layout.Direction = MindFusion.Diagramming.Layout.Direction.Straight;
layout.IgnoreNodeSize = false;
layout.LinkType = MindFusion.Diagramming.Layout.LayeredLayoutLinkType.Cascading;
layout.KeepGroupLayout = true;
layout.MultipleGraphsPlacement = MindFusion.Diagramming.Layout.MultipleGraphsPlacement.Vertical;
layout.Orientation = MindFusion.Diagramming.Layout.Orientation.Horizontal;
layout.SplitLayers = true;
Reply #3 - Oct 15th, 2009 at 5:49pm
LayeredLayout should set the links' SegmentCount to at least 3 segments. Perhaps you have some additional code after the LayeredLayout.Arrange call that changes it to 2?
