Normal Topic How to make a readonly diagram ? (Read 3524 times)
Mohammad
Hello everybody :)
Oct 21st, 2009 at 1:01am
Hi
I want to make diagramView readonly in some cases. It means to avoid users to create or change the diagram nodes and links and their positions.
I tried to do this by setting Behavior property to DoNothing in server side but it dosen't work! I use diagramView in JavaApplet mode and use ShapeListBox to add custom nodes to the diagram.
Is there ReadOnly property to both diagramView and shapeListBox?
Thank you.
Re: How to make a readonly diagram ?
Reply #1 - Oct 21st, 2009 at 9:46am
Behavior only specifies what happens when you draw on the canvas with the mouse. Do you need to disable creating nodes using drag-and-drop from the ShapeListBox?
Mohammad
Hello everybody :)
Reply #2 - Oct 21st, 2009 at 11:03am
Yes. All changes in diagram including drag&drop, delete, change positions and so on.
Diagram is a field in my form and when form is in view mode I should make all fields read only.
Is there a solution?
Reply #3 - Oct 21st, 2009 at 11:45am
You could set ClientSideMode to ImageMap. The diagram can't be modified then, unless you add an InteractivityExtender.
Mohammad
Hello everybody :)
Reply #4 - Oct 21st, 2009 at 12:24pm
I tested your approach but it doesn't work. I changed the ClientSideMode to ImageMap in onClick evnet of a button on the form. The initial mode is JavaApplet.
But I can change the diagram still.
« Last Edit: Oct 28th, 2009 at 6:06am by Mohammad »
Mohammad
Hello everybody :)
Reply #5 - Nov 3rd, 2009 at 11:09am
Hi Stoyon
It seems there is no solution for this. right?
Reply #6 - Nov 3rd, 2009 at 12:12pm
Is the Java console icon displayed after you hit that button? If it's still there, perhaps there's some code that changes the mode back to JavaApplet later. If you can't see it anymore but can move nodes, then you probably have the InteractivityExtender enabled on that form.
mark korn
Reply #7 - Dec 18th, 2009 at 1:51pm
Hi
You can try this:
ClientSideMode.JavaApplet
1.Edit Mode
diagramView.ClientSideMode = ClientSideMode.JavaApplet;
diagramView.Enabled = true;
diagramView.Behavior = Behavior.DrawLinks;
               shapeList.ClientSideMode = ClientSideMode.JavaApplet;
foreach (DiagramNode node in diagram.Nodes)
node.EnabledHandles = AdjustmentHandles.All;
2.Read-only Mode:
diagramView.Enabled = false;
diagramView.Behavior = Behavior.DoNothing;
diagramView.NodeClickedScript = String.Empty;
shapeList.ClientSideMode = ClientSideMode.ImageMap;
diagram.ActiveItem = null;
node.EnabledHandles = AdjustmentHandles.None;
