Normal Topic XML (Read 2231 times)
DSspirit
XML
Nov 9th, 2009 at 6:39pm
Hey,
So I'm just starting to familiarize myself with xml and the SaveToXml and LoadFromXml methods, and thus far they seem to work just fine for serializing the diagramitems, however not their tags. If you tag a diagramnode or any item to a seperate user defined class object, how do you serialize both classes and their connections to each other? Hope someone can help.
Dave
Re: XML
Reply #1 - Nov 9th, 2009 at 7:42pm
The control provides built-in serialization only for simple value types. It raises the SerializeTag and DeserializeTag events to let you save tags of other types. Use the XML DOM API to save the tag objects as elements and attributes under the tag's element you receive as event argument.
DSspirit
Re: XML
Reply #2 - Nov 10th, 2009 at 3:28pm
I was just wondering if this is the correct format for serializing a tagged object. The way I have written it I would have to write out each property of taggedElement using e.Context.WriteString, which can be tedious.
    Private Sub btnSave_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnSave.Click
        Write("file.xml")
    End Sub
    Private Sub Write(ByVal fileName As String)
        AddHandler diagram.SerializeTag, New SerializeTagEventHandler(AddressOf SerializeTag)
        diagram.SaveToXml(fileName)
    End Sub
    Sub SerializeTag(ByVal sender As Object, ByVal e As SerializeTagEventArgs)
        e.Handled = True
        Dim taggedElement As Elem = e.Tag
        Dim stringRepresentation As String = ""
        If Not taggedElement Is Nothing Then
            stringRepresentation = "ID"
            'stringRepresentation += ";"
            stringRepresentation += taggedElement.ID.ToString()
        End If
        Dim repElem As XmlElement = e.Context.XmlDocument.CreateElement(stringRepresentation)
        e.Representation.AppendChild(repElem)
        'e.Context.WriteObject(taggedElement, stringRepresentation, repElem)
        e.Context.WriteString(taggedElement.RandomNumber.ToString(), "RandomNumber", repElem)
    End Sub
Dave
Re: XML
Reply #3 - Nov 10th, 2009 at 4:52pm
If you don't want to call e.Context.Write for each property, you might use reflection to write all properties in a single loop. E.g. this code is from the ControlNode.SaveToXml implementation:
Type type = control.GetType();
string assemblyName = type.Assembly.GetName().Name;
string typeName = type.FullName;
controlElement.SetAttribute("AssemblyName", assemblyName);
controlElement.SetAttribute("TypeName", typeName);
XmlElement propertiesElement =
	context.AddChildElement("Properties", controlElement);
// Save control serializable properties
PropertyInfo[] props = type.GetProperties();
foreach (PropertyInfo prop in props)
	if (!prop.CanRead || !prop.CanWrite)
		continue;
	if (FilteredProperty(prop))
		continue;
	object val;
	try
		val = prop.GetValue(control, null);
	catch
		// Some properties cannot be read
		continue;
	if (val == null)
		continue;
	if (!(val.GetType().IsSerializable))
		continue;
	context.WriteObject(val, prop.Name, propertiesElement);
DSspirit
Re: XML
Reply #4 - Nov 10th, 2009 at 8:22pm
Thanks, that's perfect!
