Normal Topic Change the group of a node (Read 1121 times)
antonis74
Nov 10th, 2009 at 7:20pm
I noticed that when you have a node grouped with other (its not the mainitem) and you change its group by calling othergroup.attach, the node stays in the old group.
Do I have to remove it from the first group or is there something else?
Thanks in advance
Re: Change the group of a node
Reply #1 - Nov 11th, 2009 at 9:00am
If you are using the methods of the Group class, you must first detach the node before attaching it to another group. The DiagramNode.AttachTo method does that automatically.
