Normal Topic Spliting bezier links (Read 1218 times)
Dexter
Nov 20th, 2009 at 7:07am
Hi there!
Does any body knows how to prevent a link with the style set to bezier from splitting when routing? I need to route a link but doing so not to add more segments to it. Is it possible?
Dexter
Re: Spliting bezier links
Reply #1 - Nov 20th, 2009 at 11:06am
It's not possible. You might however remove the segments you don't need from the LinkRouted handler, preserving the positions of some of the control points to follow the found route. I suppose that can be done if the found route contains no more than three segments.
