Normal Topic Can't get trimming to work in ShapeNode (Read 1946 times)
jf2020
I love FlowChart!
Nov 24th, 2009 at 3:17pm
Good day,
I 'm trying to get an ellipsis a the end of the text when it doesn't fit in the bounds.
For that I'm doing
box.TextFormat.Trimming = StringTrimming.EllipsisCharacter
but I don't get the ellipsis to show.
I did a search and found a post about the same thing but in table cell. I have tried to set
 EnableStyledText =false
but that didn't help.
What am I doing wrong?
Re: Can't get trimming to work in ShapeNode
Reply #1 - Nov 24th, 2009 at 3:25pm
Try also setting PolygonalTextLayout = false.
jf2020
I love FlowChart!
Reply #2 - Nov 25th, 2009 at 7:55am
Thanks! This indeed works now.  Smiley
As an additional question I was wondering if there's an easy way to know if the text is trimmed. I'm using the box as a label and I would like to set a tooltip to it containing the full text, but only when the text is trimmed.
Reply #3 - Nov 25th, 2009 at 8:21am
You could use the Diagram.MeasureString method to check if the string is larger than node.Bounds. I'm not sure how it will work with text wrapping enabled though. The override that takes maxWidth argument might be useful in such case.
