Normal Topic Prevent node overlapping (Read 1866 times)
oOAnriOo
Nov 26th, 2009 at 8:29am
I'm working on a project where the user can place nodes as he pleases.
The only restriction I want is that i don't want any nodes to overlap.
Is there any way i can use a layout to move ONLY nodes overlapping other nodes (and just move them to the next "clear" spot) or can I do it using code somehow?
Re: Prevent node overlapping
Reply #1 - Nov 26th, 2009 at 9:53am
Try running a few iterations of SpringLayout, possibly with SpringLayoutTraits.Frozen set to true for all other nodes except the new one.
If that doesn't work, we could add a method that finds some unoccupied space for a node using the obstacle map built by the link routing algorithm.
TimNZ
Reply #2 - Nov 29th, 2009 at 10:44pm
Yes please!
