Normal Topic Overview Control Problem (Read 4210 times)
Anshul
Senior Member
Dec 3rd, 2009 at 9:46am
Hi Stoyan,
I am using following code for overview window of diagram.
Code in XAML
<diagram:Overview x:Name="overview" FitAll="True" />
Code in XAML.cs
overviewWindow = new OverviewWindow();
                   overviewWindow.Owner = this;
                   overviewWindow.RenderSize = new Size(300, 300);
                   overviewWindow.Visibility = Visibility.Visible;
                   overviewWindow.Background = System.Windows.Media.Brushes.White;
                                           overviewWindow.overview.Document = diagram;
                       overviewWindow.overview.Height = overviewWindow.Height;
                       overviewWindow.overview.Width = overviewWindow.Width;
                       overviewWindow.overview.HorizontalAlignment = HorizontalAlignment.Stretch;
                       overviewWindow.overview.VerticalAlignment = VerticalAlignment.Stretch;
The above code channging Height and width of the overview  in accordance with window size.
But even if we are not changing window size , but we are changing the zoom factor of diagram , height and width of overview is also getting changed.
We want fixed size of overview irrespective of zoomfactor.
Please suggest for this.
Anshul
Anshul
Senior Member
Re: Overview Control Problem
Reply #1 - Dec 4th, 2009 at 2:06pm
Hi Stoyan,
Any updates on this.
We are sending you sample regarding this.
Thanks and Regards,
Anshul
Reply #2 - Dec 4th, 2009 at 3:27pm
It seems the overview does not allow the scale to be larger than 100%, even in FitAll mode, which would happen in your case. Our developer can't think of any particular reason why that limitation was added; we'll see if we can remove it for the next release.
Anshul
Senior Member
Reply #3 - Dec 7th, 2009 at 2:42pm
Hi Stoyan,
We are facing one more problem with this.
When we resize the window which contains overview control has repaint issue.
It gets repainted slowaly , and window over window appears.
This is reproducable in the same sample which I have already sent you.
Steps:
1.Run the Application.
2.Click Overview Window Button.
3.Do Rapid Resize the overview window.
Is there any way to avoid this.
Please Suggest for this.
Thanks and Regards,
Anshul
Reply #4 - Dec 8th, 2009 at 9:52am
I don't think this has anything to do with the overview. You can see the same effect if you start resizing a notepad window over the buttons below the diagram.
Anshul
Senior Member
Reply #5 - Dec 16th, 2009 at 10:38am
Hi Stoyan,
This is with reference to  following link.
http://mindfusion.eu/Forum/YaBB.pl?board=wpfdg_disc;action=display;num=126085564...
The Problem with overview control still persist.
Height and width of the overview should change in accordance with window size.
Anshul
Reply #6 - Dec 16th, 2009 at 1:04pm
Using the "Overview window" project you emailed us for this and references to the v2.3 assemblies, I can see only the size of the tracker rectangle change when zooming out; it shows what part of the diagram is currently visible in the scrollviewer, so its size is expected to change.
