Normal Topic Custom DragEvent (Read 5029 times)
Waterfiets
Custom DragEvent
Oct 8th, 2013 at 7:31am
Hi There,
At the moment I'm working on DragPreview thingy. See example below.
Basically i have a NodeListView on the left from where i want to drag the nodes on the diagramfield(Which works). While I'm doing this i want to get a preview of the node before i drop it on the field. Comparable with function ModificationEffect.MoveShades does when i move a node in the diagram only.
What I've tried so far is in the example code below.
   protected override void OnGiveFeedback(GiveFeedbackEventArgs e)
            base.OnGiveFeedback(e);
            if (e.Effects.HasFlag(DragDropEffects.Copy))
                Mouse.SetCursor(Cursors.Wait);
            else if (e.Effects.HasFlag(DragDropEffects.Move))
                Mouse.SetCursor(Cursors.Cross);
            else
                Mouse.SetCursor(Cursors.Hand);
I tried overriding several GiveFeedbackEvents, dragevents and mouseevents in my NodeListView class. To see if it was working i kept the logic simple, just for testing purposes, hence the cursors.wait setting, i know this doesn't give me a preview. But it didnt give me a wait icon or cross icon either.
Could anyone give me any insight?
Thanks in advance.
Greets,
Sander
Re: Custom DragEvent
Reply #1 - Oct 8th, 2013 at 9:08am
Try also setting these properties:
e.UseDefaultCursors = false;
e.Handled = true;
Waterfiets
Reply #2 - Oct 8th, 2013 at 9:29am
Thanks, that worked somewhat.
Does Mindfusion have a standard property that gives me the possibility to have a preview of the node under my cursor?
Greets,
Sander
Reply #3 - Oct 8th, 2013 at 10:07am
There's no such property. You could create an actual node from DragEnter and update its position from DragOver event handlers.
Waterfiets
Reply #4 - Oct 8th, 2013 at 10:44am
Hmmm.
Do you happen to have an code-example?
Greets,
Sander
Waterfiets
Reply #5 - Oct 8th, 2013 at 10:50am
Something like this perhaps?
    if (e.LeftButton == MouseButtonState.Pressed)
        // Package the data.
        DataObject data = new DataObject();
        data.SetData(DataFormats.StringFormat, circleUI.Fill.ToString());
        data.SetData("Double", circleUI.Height);
        data.SetData("Object", this);
        // Inititate the drag-and-drop operation.
        DragDrop.DoDragDrop(this, data, DragDropEffects.Copy | DragDropEffects.Move);
Reply #6 - Oct 8th, 2013 at 11:09am
Nothing like that, more like this:
DiagramNode dragIndicator = null;
private void OnDiagramDragEnter(object sender, DragEventArgs e)
	if (dragIndicator == null &&
		e.Data.GetDataPresent(typeof(DraggedNode)))
		var data = (DraggedNode)e.Data.GetData(typeof(DraggedNode));
		var position = e.GetPosition(diagram.DocumentPlane);
		dragIndicator = (DiagramNode)data.Node.Clone(false);
		dragIndicator.Move(position.X, position.Y);
		dragIndicator.Opacity = 0.5;
		diagram.Nodes.Add(dragIndicator);
		e.Effects = DragDropEffects.Copy;
		e.Handled = true;
void OnDiagramDragOver(object sender, DragEventArgs e)
	if (dragIndicator != null)
		e.Handled = true;
private void OnNodeCreated(object sender, NodeEventArgs e)
	// NodeListView creates an instance automatically, so remove the indicator
		diagram.Nodes.Remove(dragIndicator);
Waterfiets
Reply #7 - Oct 8th, 2013 at 11:52am
Stoyan you're a Genius, it works!. If you'd be living in The Netherlands i would have given you a chocolate bar.  Grin
Reply #8 - Oct 8th, 2013 at 12:13pm
You can always post it to address from http://mindfusion.eu/contacts.html Cool
