Normal Topic TreeLayout (Read 1996 times)
oOAnriOo
TreeLayout
Dec 8th, 2009 at 10:57am
I'm trying to get an automatic treelayout out of this diagram
All nodes are based on DiagramNode, the white boxes in the node named "Zulu 1" are attached DiagramNodes with anchors and they are fixed to the mother-node using AttachTo and IgnoreLayout.
Now, when I autoarrange i get this result.. ..the subnodes are placed in the top in stead of under the "Zulu 1" node.
What might I be doing wrong?
Re: TreeLayout
Reply #1 - Dec 8th, 2009 at 1:14pm
What happens if you set TreeLayout.KeepGroupLayout instead of setting IgnoreLayout on the anchor nodes? This should make the layout function regard the whole group as a single node, whereas IgnoreLayout will disconnect the tree.
oOAnriOo
Re: TreeLayout
Reply #2 - Dec 9th, 2009 at 9:04am
Yep.. That did the trick.
However when I autoroute using treelayout i get this result:
The link on the left side runs along the side of the root node. If I move it manually the link realignes the way I want :
Is there any way I can control that?
Sorry for the cascade of questions. I like your product a lot but cant seem to locate my ansvers in your documentation.
Re: TreeLayout
Reply #3 - Dec 9th, 2009 at 9:42am
You could call diagram.RouteAllLinks() after TreeLayout.Arrange().
