Normal Topic Questions about lauouts. (Read 1215 times)
oOAnriOo
Dec 14th, 2009 at 7:27am
Thanks for all your help so far.
I'm getting close to finishing my project but I have 2 unresolved issues you might be able to help me with.
When i use the TreeLayout i sometimes need to arrange a single level in more than one row. Is that possible.
My tree wil rarely be more than 2 levels deep, so it won't clutter on most occations.
Is it possible for force the layouter to locate as much as possible on the visible area before drawing outside it. Often if I have many objects in level 2 of my treelayout, it locates nodes completely og partially outside the visibla area while there is still plenty of free space to draw on.
Re: Questions about lauouts.
Reply #1 - Dec 14th, 2009 at 10:06am
Here is a possible way to do this:
void ArrangeTree(int levelToSplit, DiagramNode root)
	List<DiagramLink> tempLinks = new List<DiagramLink>();
	List<DiagramNode> levelNodes = new List<DiagramNode>();
	GetLevel(levelToSplit, levelNodes, 0, root);
	for (int i = levelNodes.Count / 2; i < levelNodes.Count; ++i)
		DiagramNode node = levelNodes[i];
		tempLinks.Add(diagram.Factory.CreateDiagramLink(
			levelNodes[i - levelNodes.Count / 2], node));
		node.IncomingLinks[0].IgnoreLayout = true;
	// run it with your current settings
	new TreeLayout().Arrange(diagram);
	foreach (DiagramLink link in tempLinks)
		link.Destination.IncomingLinks[0].IgnoreLayout = false;
		diagram.Links.Remove(link);
void GetLevel(int level, List<DiagramNode> leveNodes, int currentLevel, DiagramNode node)
	if (currentLevel == level)
		leveNodes.Add(node);
	else
		foreach (DiagramNode child in node.Query("outlinks/destination"))
			GetLevel(level, leveNodes, currentLevel + 1, child);
You could call diagram.ResizetoFitItems after applying the layout, and then set Bounds to its union with the minimal diagram area size you need.
