Normal Topic Node Deleting and Link Deleting Events (Read 1409 times)
rajesh_patil74
Dec 14th, 2009 at 1:08pm
Hi Stoyo
For some requirement I extended the Diagram Control and attaching popup menu with the links created. The popup menu is handled within the newly derived class.
One of the menu item removes the link by invoking the this.Links.Remove(link)
Now, whether the link should be removed or not is checked by my control which contains the derived diagram control.
Here my requirement is I need events which can cancle the delete action based on validation.
How I can achive this or when we have events like OnLinkDeleting/OnNodeDeleting or OnLinkBeforeDeleting/OnNodeBeforeDeleting ?
-Regards
Rajesh
Re: Node Deleting and Link Deleting Events
Reply #1 - Dec 14th, 2009 at 2:08pm
Hi Rajesh,
Links.Remove calls the protected Diagram.RemoveItem method to remove the link. You could override RemoveItem and raise validation events from it. To cancel the action, simply don't call the base RemoveItem implementation.
