Normal Topic Incremental TreeView with diagram lite (Read 1633 times)
rajesh_patil74
Dec 17th, 2009 at 1:19pm
Hi Stoyo
How one can create a incremental tree with mind fusion diagramlite control like the one shown on following link
http://www.goxam.com/GoSilverlight/GoSilverlightDemo.html
Select the incremental tree item from the listbox.
Or something like
http://image-swirl.googlelabs.com/html?q=eiffel%20tower#131
Re: Incremental TreeView with diagram lite
Reply #1 - Dec 17th, 2009 at 1:50pm
Hi Rajesh,
To create nodes on demand, set ExpandButtonAction = RaiseEvents, handle the ExpandButtonClicked event and create the child nodes and links from that handler.
For arranging the new tree, try using TreeLayout.Type = Radial or SpringLayout with EnableClusters set to true.
If you are most interested in the animations, I suppose you could run the layout on a copy of the diagram, and then animate the nodes in the original diagram to the new positions set by the layout object on the copy.
