Normal Topic Diagram performance problem (Read 2776 times)
Niranjan
Dec 21st, 2009 at 2:19pm
Hi There,
I am using Diagram control in my Silverlight application.
What I have noticed is when I provide less data then the diagram works fine. But as my data increases the the performance is very slow. Even after my diagram is rendered when I use the Scrollviewer to scroll the diagram it is very slow.
I have uploaded the sample at
http://cid-2af8f2fa2ffcfc13.skydrive.live.com/self.aspx/.Public/SilverlightAppli...
Please help me to improve the performance with large data.
Thanks in advance Smiley
Niranjan
Re: Diagram performance problem
Reply #1 - Dec 21st, 2009 at 4:03pm
Remove the shadow effect, and it works much much faster.
Niranjan
Reply #2 - Dec 22nd, 2009 at 5:11am
Hi Stoyan,
Thank you very much for your reply.
Ya after removing shadow effect the performance is increased.
Is there any workaround that if I want to show some effect and still I get good performance??
Thank you so much once again!!!
Niranjan
Reply #3 - Dec 22nd, 2009 at 6:42am
Hi Niranjan,
If there was a way to detect the scroll position change, you could handle it to add shadows only to the currently visible items. I can't seem to find any events for this in the ScrollViewer class though.
If there won't be much interaction with the tree, you might instead try to add a second set of links at the back of Z order, with their Stroke set to Gray to appear as shadows, and with a small offset from the original links.
