Normal Topic Moving nodes from NodeListView to Diagram (Drop) (Read 2177 times)
wladek
Jul 20th, 2010 at 11:10am
I have the following problem. Instead of copying the nodes using copying constructor and drag&drop I would like to move the object from NodeListView to Diagram or at least make a duplicate and then delete the prototype. The problem is that that I cannot intercept the Drop event. Xaml looks like this:
[code]
<diag:Diagram x:Name="diagram"
AlignToGrid="True"
ShowGrid="True"
Bounds="0, 0, 1000, 1000"
NodeCreated="OnNodeCreated"
NodeCreating="OnNodeCreating"
NodeModified="OnNodeModified"
LinkCreated="OnLinkCreated"
ShapeBrush="LightBlue"
DefaultShape="Rectangle"
MouseRightButtonDown="OnDiagramRightDown"
MouseRightButtonUp="OnDiagramRightUp"
AllowDrop="True"
Drop="OnDiagramDrop"/>
[/code]
And the handler simply:
[code]
private void OnDiagramDrop(object sender, DragEventArgs e)
[/code]
I assume that In the handler I could do what I want to but I just cannot force the app to handle (fire?) the event.
Re: Moving nodes from NodeListView to Diagram (Dro
Reply #1 - Jul 20th, 2010 at 12:28pm
Our drag-and-drop implementation does not use this Drop event. It seems Drop was added to the base UIElement class with Silverlight 4 and it works only for dragging files from Windows Explorer to a SL control.
The Diagram control will raise NodeCreated in that situation. You could recognize that the new node comes from the NodeListView by setting some property of the listview nodes (e.g. Tag) to a specific value and checking for that value in OnNodeCreated.
wladek
Reply #2 - Jul 20th, 2010 at 3:52pm
This approach is the workaround I was working on, but it is still a workaround. Is there a way to modify the built-in behaviour to have the node moved and not copied?
How to switch off the default behaviour? Does it base on MouseUp event?
Reply #3 - Jul 21st, 2010 at 7:27am
This version adds a DragDropCompleted event:
https://mindfusion.eu/_beta/diaglite18_dragdrop.zip
private void OnDragDropCompleted(object sender, NodeListViewEventArgs e)
	var listView = (NodeListView)sender;
	listView.Items.Remove(e.SourceNode);
